enable rip aggregation
        Description
      Enables the RIP aggregation of subnet
                information on a RIP version 2 (RIPv2) interface.
        Syntax Description
        Usage Guidelines
      The enable
(disable) rip aggregation command enables (disables) the RIP aggregation
of subnet information on an interface configured to send RIPv1 or
RIPv2-compatible traffic. The switch summarizes subnet routes to
the nearest class network route. The following rules apply when
using RIP aggregation:
                    - Subnet routes are aggregated
                        to the nearest class network route when crossing a class boundary.
- Within a class boundary, no
                        routes are aggregated.
- If aggregation is enabled,
                        the behavior is the same as in RIPv1.
- If aggregation is disabled,
                        subnet routes are never aggregated, even when crossing a class
                        boundary.
      The following command
enables RIP aggregation on the interface:
      # enable rip aggregation
